configure cfm group add rmep
configure cfm group group_name add rmep mepid
Description
This command allows you to create and associate an RMEP to a group.
Syntax Description
mepid
Specifies the MEP ID of the remote MEP being created. The range is 1 to 8191.
Default
N/A.
Usage Guidelines
Use this command to create and associate an RMEP to a group.
configure cfm group “eapsCfmGroup” add rmep 2
This command was first available in ExtremeXOS 15.2.
Platform Availability
